Daniel
Carpal tunnel level member
- Suburban Philadelphia (Wayne)
starts around 11:00
this is the most intense clip I have ever seen...
Yea, his fall vid came out not real long after this one did, messed himself up pretty good. And I agree that Dan's tree service vid was funny as hellWatch his post fall video? (Like 5min after, EMS arrival included)
Horrible thing to experience.
His "F#%£ Dans Tree Service" video is hilarious
That was wal-nuts! It would have worked better had it been slash cut so the butt slides off the crotch instead of tipping it over with notch. Any which way you cut that much wood into rigging and all of it is above you, it is going to be terrifying.
He did not have the ground guy he needed to be trying to do what he's doing. He puts a rookie ground guy in a scary spot, trying to handle sketchy rigging set up. I've been under that scene before. If the groundie doesn't have the nut to speak up and climber doesn't have the foresight to see what's about to happen, no bueno.... if my ground slowly lowered a piece of wood onto/through the only little obstacle under me like that, I'd be on the ground and pissed. That was just dumb. I started from the beginning and up until they crushed that fence everything seemed all good.
Slash cut okay maybe but that creates undue shock load which should always be avoided imo
Thanks for posting. Prayer for his full recovery. I like this guy hope to see more of him soon.
- it wasn't tip tied/tied to low
- nobody was on the lowering rope? looked like it was locked off? filmer
- should have been winched into the rig point/stand it up keep it static with line control on the butt
- tip could of been held by third person to avoid wild swing
- he could of made the cut near to severing point and got of the tree to help snap it out
- like others have said smaller pcs with control line to avoid wild swing
I try to imagine the full outcome and wage, how much is this going hurt? Continue or adjust plan? Breath, drink water, talk it LOUD, get out of tree and step back and check it from another angle.
We all really enjoy the work,the rush, the fear and the challenge of completing.
no injury, bit of bruise, major contusion, broken bones and bleeding or maybe dead.
How do you see it? What questions are you asking yourself before you make the cut?
In with Daniel for the most part about the winching / lifting.We may have a issue with definitions, but I disagree with a lot of the above.. generally its just faster easier to use gravity, rather than winching, which is almost never needed with a good rigging set up.
and to answer the question:
Before making cut ask yourself "if I do this will I die here?"
second question is "AM I sure?"
