TimberJack
- Westchester County, NY
Wider is better!!! The MT 55 I run at work is the narrow track version and has been tipped over a handful of times.
Theres no doubt the minis are great labor savers, and Toro has one of the most turf friendly track tread patterns I have seen, not to mention the 1000's speed, superior GPM, crazy strong tipping.
That said if you are laying down a lot of alturna mats for your track minis and you hate it.
Then the no need for mats is just one of the reasons articulating machines are the next level up in forwarding machines.
The grapple discussions are hilarious
I learned til it hurt that the bmg sucks.............
Colb what do you run a BMG on? (Mini or articulating.)
I can't really drag things with the vermeer grapple, with no rotational freedom in the up/down plane. With full size brush clumps, I can't get it around the tight corner as easily without putting the tips down at some point. With the bigger logs, well, I was dragging 20' 20" pine logs around a dirt pasture the other day. Can't do that without all axes of rotation...Ditch Witch Sk650 mini
I disagree and your experience does not impress me as I have over twice what you have. Also since you sell the BMG you just might be a little biased. The Bmg has the weight out too far, loses lift height compared to a "clam" style grapple...and you can doze pieces apart and together if nec to grab a bunch if desired with a "clam" grapple. "Imperacly" "Emperically?" the grapple I use is far superior to yours which cannot doze pieces as well and flops when trying to dive between pieces. I've had em both....yours sucks...although the power rotating unit must be a big improvement.
Each grapple has its advantages but for moving brush and feeding chippers the bmg non power is key. I run an old implemax on a swinger and I can feed and load like it's an extension of my body.I disagree and your experience does not impress me as I have over twice what you have. Also since you sell the BMG you just might be a little biased. The Bmg has the weight out too far, loses lift height compared to a "clam" style grapple...and you can doze pieces apart and together if nec to grab a bunch if desired with a "clam" grapple. "Imperacly" "Emperically?" the grapple I use is far superior to yours which cannot doze pieces as well and flops when trying to dive between pieces. I've had em both....yours sucks...although the power rotating unit must be a big improvement.
Some of the most unproductive and biggest hacks in my area are the tree services that advertise 25+35+ years experience ect. Just because you've been doing it a long time doesn't mean you've stepped out of the stone age. Hell some of them are still lashing piles of brush with a rope and dragging them to the chipper, then chipping by hand. I've used both and by far prefer the bmg over the clam jobbers on the mini.I disagree and your experience does not impress me as I have over twice what you have.
We all want to be efficient. We try to either eliminate employees or make it easier for everybody to do the work. We still need the employees to drive the trucks to the jobs. These days, a wheeled Zahn with a bmg or an avant is the best for residential. The Zahn is best for brush as it doesn't lift but #400 and the avant picks up #1,200. Each person has what works for them and I feel the aggressive talk about Dave is uncalled for. I feel just meeting him a couple of times that he's a honest and fair person and lead a prospective buyer or non buyer to what works best for themSome people just don't get it,
I doubt most people even know what it is,
or have had the treat of forwarding on a swinger with an implemax
Heres a Toro! oldies but goodiesView attachment 41027
View attachment 41028 View attachment 41028
