No, that is the 427. An older one. But still a good one.Royce, is that the tx 1000?
Skip to 10 minutes.
I think you were going at it wrong.It needs to be said since I owned both at the same time that the BMG doesn't open wide enough to get a big bouquet of branches to drag to the chipper. You will be lucky to grab 2 or 3 while you fumble to get the pinchers to drop below the stems to grab some. Simply does not open wide enough to drag multiple branches (which is what you have after limbing).
Take 20' or so of old climbing line and attach a heavy duty snap to it....run the line around 10 or 12 big branches or more and snap it back onto itself(a r Bowline works too) then tighten it up and then attach to a porty on the clam grapple while down and cinch as tight as possible and lock off. Pick up a mass pile of branches and drag them to the chipper. TX 1000 moves houses.
As for say you bomb out a big TD and you have logs everywhere. You get Dustin or Justin or Josh or whoever is your grounddoggy that week to get all the brush out. Then you can run the clam grapple (mine is a Toro) into the logs and grab 2 or 3 after they align themselves.
BMG is a major pain in the ass. Flops all over and is just like trying to grab a stuffed animal in those games in restaurants where you can never get one. It is certainly useful...but second rate. Dealers and likely forum owners that are paid by them will disagree.
If you have to run a long log between 2 tight buildings like in the pictures...that is the only place the bmg beats the clam...but how often is that a problem? And much easier to load the logs sideways into a dump trailer with the clam than with it sticking out like a weinie in front of you.
As for loading logs. With the bmg you can load them sideways over a trailer's side, just like a clam...but better cause you can reach more. That said, I find it much easier to stuff my weinie in from behind with the bmg.
