If you don't get hurt and don't break anything it's not cheating it's doing it right. If you have a light system smaller pieces if you have a heavy system bigger pieces that's smart good rigging don't knock on that.Dang thumbs on the phone, I hit post by accident. I admit I cheat with the rings when negative rigging smaller chunks, but otherwise, I try to take heavy picks, so I use the big gear.
You can narrow your choices by asking yourself what kind of jobs do you do 90% of the time. Honestly we have shorter trees than a lot of the videos you see on YouTube etc so we can't take monster pieces to rig due to lack of space so a 1/2" system holds what we do.Great discussion going on here guys. There are so many options and it doesn't seem like a "right or wrong" one, just preference.
Cost isn't that big of an issue, so I may buy a bigger block and a 1/2" rope. then there are the slings too.. So many choices!!
Sorry, I should have clarified. By cheating I meant that I have negative rigged off of a single ring. But after this thread, I went with two today. Thanks guys for helping me break that nasty habit.If you don't get hurt and don't break anything it's not cheating it's doing it right. If you have a light system smaller pieces if you have a heavy system bigger pieces that's smart good rigging don't knock on that.
Yeah any rope up to 3/4" is fine. A block really can't be to big. A small bend radius is not a great thing but bigger is fine, it'll sit down into the pulley deeper is all.I first bought a omni block/sling combo for smaller 1/2'' rope stuff and would just natural crotch with a 5/8 rope for the bigger pieces. I just bought http://www.treestuff.com/store/catalog.asp?category_id=235&item=12399 for my first big block. I don't know if I will ever use 3/4 rope with it but it should run fine with my 5/8 right? It seemed like a cool block, priced well, and just came back in stock. Has anyone else used it? I have a 3/4 12' Yale dead eye sling for it too
Do you fee lucky?If I am taking pieces of a spar, will a 1/2" rope be strong enough, as the load will be dynamic?
These kind of questions raise concern. There are sooo many variables! Stay safe. I would recommend finding a mentor. Someone who "knows the ropes"If I am taking pieces of a spar, will a 1/2" rope be strong enough, as the load will be dynamic?
Maybe if you are negative rigging an 18" spar and you take them relatively small. But yeah, lots of factors and variables at play. I would bite the bullet and get a 5/8" line if you are blocking down spars. If you have to rig the wood, chances are you can't afford to have the rope snap on you. Your insurance claim/damage will likely cost you much more than that 150-200 dollar 5/8" rigging line. Look into vertical speedlining as wellIf I am taking pieces of a spar, will a 1/2" rope be strong enough, as the load will be dynamic?
That depends on the line and the size of the piece if you use 3 strand 1/2" yellow poly you may running an issue trying to take decent size pieces. But likely you are using a durable rigging line staying within you swell and comfort levels so you should be fine.If I am taking pieces of a spar, will a 1/2" rope be strong enough, as the load will be dynamic?
