I’ve made a usaver with: 2 7/16 in steel ring, pinto pulley used with spacer, 10mm Sirius and 8mm I’ve tail. Usaver works as it should I’m hanging basket configuration and retrieved fine.
When used in choked configuration, the pulley will wedge into the stem of the tree and the ring at the same time, even though the pulley fits through the ring at all angles and can fit through without touching the ring at all.
Has anyone else encountered this problem? If so how did you fix!?
