Welcome to Treebuzz. I learn a lot popping in from time-to-time.
The following is more info than I usually give out, not because I'm secretive but most folks frankly are just not that interested. but here goes:
If you have access, say a library copy, of a Myxomycete text, check out Lycogala flavofuscum and see if that fits on a macro basis. That might be all you need.
If you really need to rigorously ID it, a microscope at
100x would likely be enough magnification. if the optics are good enough to provide a sharp image. Resolving power is at least as important as magnification, but it would need to be more than a toy. I'd probably start with *small* amounts of sample on a microscope slide, mounted in water. I'd also probably make a slide with cotton blue in lactophenol and one in Melzer's reagent. I'd be looking for spore ornamentation (pits, spines, warts) and sometimes the dyes help in showing that stuff. If you're not used to doing that stuff or don't know what I'm talking about, then your need is beyond what Treebuzz can provide. Even at 100x, the spores will be quite small, but you should be able to see the diagnostic ornamentation. The pseudocapillitia of Lycogala are like wide, empty tubes as distinct from true capillitia that are usually narrow and forked/branched. Again, the above is routine for a diagnostic lab, but would be overkill for most arborist applications. But like I say, you asked! Happy to help!
