Birdyman88
- Arlington
So I was cutting a large oak log today and something happened that got me scratching my head. The log was a downed 20 ft trunk about 30" diameter at end, and about 48" diameter at the last cut near stump. It was too risky to get on top of log, so I had bars long enough to cut in each piece in one pass. Everything was done with a 661, stock, with muffler mod. The two b/c setups were as follows.
Used Stihl ES 36" bar, used Stihl 3/8 .050" RS full chisel full complement chain, sharpened to stihl specs, rakers at .025".
New Forester Pro 52" bar, new Forester 3/8 .063" full chisel full skip chain, rakers factory at .025"
I have a lot of time with the 36" setup so I know how it cuts. I was expecting slow cut times with the 52". Well, I was totally surprised when the cut times of 52" totally blew away the 36". Not by a little, but by a lot. The times for the 52" in 48" wood were easily 2/3 of what 36" was in 33" wood. Plus that 661 purred like happy cat as long as didn't try to stand on it too hard. Chips were better defined on the 52" as well. The 52" had much more noticeable grab and I got to experience what a 661 REALLY feels like when it pulls in.
I sat out in the shop tonight making some measurements on the two chains, and I swear everything is almost identical, EXCEPT for tooth height - the 52" is taller. I looked at sharpening angles, depth gauges, distance from raker peak to tooth, angle of raker, gullet, and so on. Any thoughts?
The 36" chain is on top
The 52" chain on bottom
