Gear question
Yeah I still prefer something more definite but each to their own.
I was rather weird about them when they came out. Now that it has been a couple of years and nobody has died, I've mellowed. They're terribly handy for things like creating solid D rings on the petzl falcon. Just put it through the side rated point and zip tie around it to make it stand proud.
It is petzl, after all. And they're using them as the anchors in rope bridge saddles. They've broken them every which way and decided that this design is trustworthy enough.
I would believe that a double locking/ triple action/ movement carabiner is more likely to unintentionally come open, than the Ring Open is likely to vibrate the bolt out. You can also cover the Ring's connection with one of Petzl's rubber grommets to prevent loading it.
You are probably right, I think it’s just that I grown used to what I use and have grown comfortable with it. Change feels weird
Rope bridges see a lot of repetitive action over a small span. I would not put a biner on a bridge unless it was fairly necessary. Most of them have rough edges that will repeatedly abraid and pick the short section of rope. Additionally, it increases the capacity to load the gate, and/or rotate the locking mechanism - one more piece of complexity. Rings are standard and very simple. So is the abr radius, which is compact and has a big bend radius. The rook gets mixed reviews - usually due to their long length (bad), bulky volume and weight (bad), big bend radius (good), swivel action (good), multiple attachment points to simultaneously use multiple climbing systems (good), and smooth pulley action (good). Girth hitching a sling to the bridge is likewise better as a temporary measure due to repetitive friction on the same small length of rope, plus the loss of the intended functionality of the bridge as a work positioning assist. The petzl ring is attachable, but you'll need to inspect the screws regularly. Good luck, be safe, replace your bridge as appropriate and replace it correctly.
All good points. I want to add that a hitch climber pulley would work very well here. It can be attached and removed in seconds and gives you three attachment points.
Reactions: Evo
I don't like that. The swiveling ones(hydra, rook) will keep you from flexing the plates apart over and over. That twisting load is not something that the hitch climber is rated to handle.
