Ford 6.0 powerstroke help guide.
we recently here at maui tree, acquired a 6.0 with a nice arbor box and it got us a few months of work done, before it finally quit on us. over the past few months i have educated myself with the common failures and fixes for these trucks so i have decided to share what i have learned with yall.
first things first, in 2002-2003 ford was producing the 7.3 powerstroke diesel which was a really reliable engine for the day. they had alot of sales and successes with theses trucks in both the ambulance and commercial fields, to the everyday truck owner. around this time chevy came out with the 6.6 duramax diesel which had new tech and better MPG and fewer emissions. ford decided they would re visit the 7.3 and design a completely different motor with fewer emissions then the duramax and even higher tech components. this, is where ford eventually failed in the design of what was supposed to be their flagship new motor. they were under alot of pressure to put out the new 6.0 and in the early 2000's, ford was lacking diesel service technicians and designers so they outsourced their components from a new factory. the major issue this factory had was they did not clean their blocks properly after the casting process was over. what was left behind is up to 2 pounds of silica sand in all the nooks and crannys of the motor. this eventually led to failures in the HPOP's(high pressure oil pumps), the IPR valves getting clogged or damaged due to debris and the oil cooler getting clogged with silica sand. with all that being said, i dont believe they are poor trucks at all. if you can get a 6.0 now days for a cheap price, heres a list of things to consider replacing.
EGR COOLER: all 6.0 eventually need a new EGR cooler a they get leaky and will clog the EGR valve and run poorly with bad emissions ex(rolling coal).
OIL PUMP: the early 2003-2004's require a new oil pump as the factory pumps get destroyed by debris and faulty gaskets, 2005-2007's require the same as the early models only the STC fitting for the HPOP can also break seals and need replacing.
OIL COOLER: because of the silica sand in the casting process, the passage ways in the oil cooler where the coolent is supposed to flow through get plugged and corroded. this is something that needs replacing in all 6.0s along with new gaskets and O rings.
IPR VALVE: this valve sends a signal to your trucks ICP and FICM telling it how much oil pressure is being created and thus the ficm will regulate and distribute the right amount of oil needed to go to the fuel injectors.
FUEL INJECTORS: the 6.0 ford uses HEUI injectors that use the high pressure engine oil to hydraulically actuate a piston in the injector that squirts the fuel into the cylinders. these become damaged due to faulty seals and O rings leading to massive blow by of oil. ford has an entire plant dedicated to just re manufacturing the 6.0 injectors(big money in that!!) as they cost $350 per injector.
OIL/FUEL RAIL: the rails that the injectors mount to are fed by the HPOP and often blow nipple cup seals and dummy plug seals. its important they while you do an injector job to also get new seals and rings for the rails.
FICM: the last and final thing i want to share about really concerns me. ford has major issues with the printed circuit board in the Fuel Injection Control Module or FICM("Fickem"). they break solder joints and cause a major malfunction that will make your truck not run sometimes and run fine other times. if you have injectors misfiring or an extremely rough idle it wouldent hurt to check into your trucks FICM components and possibly getting a new one.
to sum it up, after these parts are replaced, i have heard of ford 6.0s running up to 300,000 miles before anything critical that leads to a trucks death. to protect your truck i recommend you change the oil on regular 3-4000 mile intervals, doing a coolent system flush, and using fuel additives like stanidine or rev-x, archoil products. if your truck is experienceing stiction, rev-x and archoil make great products for these trucks oil.
i hope this helps some of you with your 6.0's its certainly been a long and mechanical journey for me here at maui tree. i have learned more about diesel trucks in the last 4 months then i have ever wanted to know in the 6 years of arboriculture thanks to fords 6.0. haha climb safe and have fun out there
A few months ago someone on here said this is a good engine ,after investing about $5000 fixing the problems.
You've laid it out nicely for us here. Thanks for sharing.
Before reading this thread I was a tad gun shy about Ford's 6 L gong show.
You have made a compelling case that reinforces my prejudicial bias.
My '02 6.0 went 202,000 before anything went wrong, except one injector at 3,000 under warranty. I ran synthetic oil for the first 100,000 and oil changes were regular at 5,000 except for the rogue superfuckup that was 42,212 mi. This was at 90,000+/- and I really cannot figure out how I missed so many other than I got married had a child and built a house all around the same time. At 202, I dropped $2500 into the motor for oil plump oil cooler egr cooler and ICP. It ran decent until an injector dropped. Now it is sitting waiting for a decision. I am really happy with my 6.0.
Fixer for the 6oh leaker....
Egr delete
Head studs/oem head gaskets with updated seal kit
Coolant flush and external filter
Add some 4" flow/ through exhaust and Some gauges and/or monitor (boost/egt's/ficm voltage/ oil temp/ coolant temp) oil and coolant temp is to be aware of when to replace oil cooler. Ficm V to protect injectors.
And a Tune or two from reputable tuners to wake the monster!
Not canned tunes like bully dog or banks. Easy to find the guys on diesel forums.
We have a 2006 f-350 crew cab long bed 4x4 we are about to have studs and machined o-ringed heads put on. Oh and 36" toyo mtrs
I knew the truck had a head issue when I bought it for $11k booked for $24+
Gonna sink about $6k to have a dependable 400hp+ tow rig!
We also have a 2001 f-350 reg cab srw 4x4 7.3l with beans injectors and tuning/ diesel site turbo wheel and waste gate(lites at 15psi then can slap 35psi quick) / BTS transmission. 35" toyo mtrs. Set up is good for 400rwhp. Low smoke and tows loaded 12k box/dump trailer up hills at or above speed limits with respectable egts (1100-1200f) IMO sounds pretty awesome too. I have beat my buddies raptor up to 80mph by two truck lengths. 4x4boosted launch gave me a truck length off the go. I love the fact we can write off performance diesel trucks and mods!
he does know a lot....
Look into some well visited powerstroke forums, all might not quite agree with some one calling him a genius
Ahh! I suppose a well voiced opinion will find disagreement.
Source of my opinion was catastrophic failure of a 2008 6.4L F350 SRW February 2013. Took a Ford Dealership 6 weeks to determine the engine consumed 10L of oil in their testing, cylinders 7 & 8 had no compression and they didnt know why....... the 'genius' at least gave some direction on cause.
Kicker was this - engine blew up 15,000kms and two days inside warranty. Ford Canada denied all appeals (8hrs on the phone over a couple days) for warranty.
What was the cause? Sorry for your loss.
The powerstroke help guy is def informative for stock trucks, but stock diesel trucks suck IMO
Those 6. 4l have an egr system dumber then the dumb one on the 6.0's. Egr Delete is a must as is the dpf system delete. Not sure if you could get away with that in all places. Round here no problem.
Tuned and the egr and dpf gone the 6.4's produce serious dependable power like 550rwhp+ like they should with much better fuel milage. They are like the 6.0 in the fact that once you address the well known issues, you have an awesome platform and the aftermarket is unreal. Oh and most everyone knows the bad about them so the resale is let's say a buyers market. Could not imagine paying $60k for a work truck that ends up in the shop... Ever for more then routine maint.
And another thing....
If you own or are seriously considering buying a 6.0, you need a scan gauge. They can be bought at autozone for like $150ish. The can read and clear codes, but they also allow you to monitor upto four sensors at a time, of the many sensors on the engine. The ficm V is one to make sure it does not get below 46. 48v is stock mine is at 47.5v currently. At 46v and lower injectors will start to fail. The oil temp and coolant temp is another two that must be watched. When the warmed up difference is greater then 18f it is time to replace the oil cooler. Mine is around 12f delta currently. I also have the icp and irp available to see how my hpop system is functioning. Currently lower then it should, but I think the updates will fix that during the head job. If not, I get to buy a performance hpop.
I would never bring a diesel to a dealer or shop with out knowing what's wrong with it first. I have the auto ingenuity AE ford bundle software, basically what the dealer has to diagnose issues. It is an awesome tool that can pay for itself the first time you have a problem. We also have the vagcom vw/Audi diagnostics software as we own a few tdi's. I may not have the time to replace every bad part, but I do have the time to diagnose order parts and have my trusted shops finish the work. Just the other day my 7.3 has low power low boost and it turned out to be the c-clip on the exhaust back pressure valve had fallen off. Simple fix. I'd have felt pretty dumb if I'd brought that to a shop, to boot I could have been bent over for something that was fine.
Early 6.0s have also had quite a few engine wiring harness issues. I'm not positive that its a complete harness issue or if its been redesigned, but the standard practice for an early 6.0 is lift the cab, replace oil cooler, delete EGR, flush cooling system, replace the wiring harness if at all questionable, and replace headgaskets/studs especially if running any sort of tunes is planned. In a normally driven truck, this gets the reliability up to an acceptable level. For a truck that is heavily loaded and driven hard day in and day out.....I'm still not sure if it is a good engine given the fact that its not really that easy to work on when normal issues arise.
Hey it's a great engine... Once you learn how to lift the cab in 45min or less. Lol!
SOP for this gen and newer.
I was actually looking for a set up that would allow the cab to flip up with the flick of a button like some cab overs.
funny you say that. we make carbon dioxide with our trucks so, in a way, arnt we feeding the trees?
No, we make carbon monoxide by burning fuel, that's a poison. Carbon dioxide is what animals breath out and plants absorb through photosynthesis and exhaust oxogen. Its overall carbon, in all its forms, in the atmosphere that is causing problems. When we take large amounts of carbon out of the ground and release it into the atmosphere by burning, the same time as we cut down trees at a rate of 100 acres a minute we create an imbalance that warms the entire planet to the point of melting million year old glaciers and the ice caps and what not.
