- North Idaho
Nope, it's a heck of a special pulley though. Pretty much the only pulley I know of where that's possible and definitely new to the game. But point taken.So is this a block?View attachment 27772
Blocks are Yellow, Pulleys are Purple and Biners are Grey, it is really that simple, ha ha.
As well if I biner my omni 'block' on that would make it a pulley but if I spliced it into a loopie it would be a block.
And anything can take a dynamic load or shock load as long as you stay with in the swl.
If I use a biner or an xring as a 'redirect' by some definitions that would make them a pulley. They are changing the direction/ angle of the line.
According to the ISA's glossary of Arboricultural terms (1) a block is a heavy duty pulley used in rigging. Designed for dynamic loading. (2) casing enclosing one or more parallel pulleys.
http://www.treeservicesmagazine.com/article-585.aspx
Per the above article, "The obvious and most important difference between pulleys and blocks for arborist rigging applications is that a pulley lacks a bushing for sling attachment."
