theatertech87
- Rochester
I've got an avant 528 with knock around grapple that as the title says, will randomly open and close the grapple; which as I'm sure you can imagine is really annoying when carrying brush and logs. It seems to be more frequent once the machine has warmed up a bit, and when you're running multiple other functions (such as curl and lift) though it also happens without touching the controls (See video here, where you can hear the hydraulics loading and unloading).
What do you guys have for trouble shooting and diagnostics? And our local avant dealer is absolutely rubbish. I've done the best I can to check for broken/frayed wires in the control grip and found nothing, and the relays on the hydraulic solenoid, seem to be ok, and I'd rahter not swap parts until it goes away if I can help it.
