Reliable tree man
- Ontario
I would like to pick up an ABR U saver as it seems to be a very versatile tool but my question is regarding the load rating for the large steel ring. It says on treestuff that the ring is rated to 5000lb MBS. If this is the case then is the device ANSI compliant? I thought it had to be a minimum of 5400lb MBS to comply with Z133.1.
The Pulley Saver Spec sheet says that it is ANSI compliant however the MBS for the Pulley Saver is indicated as 1500 daN or 3372 lbs. I am confused as to how this can be ANSI compliant at this MBS.
Last question is what rope is the U Saver made of?
Thanks!
Thanks!
