So it's basically there to avoid osha regulations? Is it safe to say that most of osha passing at height regulations are not climbing arborists? If that's the case than it's there to bypass regulations passed by non climbers.Basically this annotation is there because there is OSHA standard language that affects line clearance arborists. This is a legit way of providing an ‘out’ to the rest of the profession
For starters, more surface area for hands, prussiks and any other devices to grab to apply friction. Possibly more material redundance in the case of abrasion or perforation. It's not just strength, it's durability and friendliness toward users and devices, as well as how it might respond to adversity.How is a larger diameter rope safer? (If a smaller rope is adequately strong,....)
That usage decision and justification is entirely up to you.Ok, so how would you justify a smaller diameter rope being safer
I can't recall ever seeing a rope access accident report where the cause would have been eliminated with a larger rope diameter.For starters, more surface area for hands, prussiks and any other devices to grab to apply friction. Possibly more material redundance in the case of abrasion or perforation. It's not just strength, it's durability and friendliness toward users and devices, as well as how it might respond to adversity.
Slightly off topic, but related to your post. I once listened to one of those funny 911 calls they get once in awhile. The caller says "My buddy is hurt bad, he needs an ambulance!" The 911 operator asks "What street are you on, sir?" The caller says "Eucalyptus Avenue". The 911 operator says "Can you spell that for me, sir?" The caller says "Uhh, I'll just drag him over to Oak Street." End of story.All arborists must be able to spell the word arborist.
<The industry collapses>
Dan, your statement started an itch I couldn't resist scratching. Here are a few basic differences I found between 12.7mm diameter and 11.5 diameter lines. I've rounded the product of my calculations to the nearest mm.I can't recall ever seeing a rope access accident report where the cause would have been eliminated with a larger rope diameter.
I get your point, but today's ropes are so good, you really have to ignore obvious defects or go way outside the bounds of reasonable usage to fail a rope.
Interesting. I have run into several people saying black rope was noticeably stiffer than other colors. I have 11mm PMI in many colors, including black, and I tend to agree.I remember a discussion with a tech rep for NER about the difference in diameter of the various color combos of Safety Blue 16 Strand.
The solid white version was the skinniest and any with black fibers in the blend were noticeably thicker. Turns out dying the fibers reduced the breaking strength. More fibers had to be added to meet specifications.
You will notice he has a small rope there to catch him when that 2" manilla one breaks.
