SRS gives you the ability to using cinching anchors with out the need for extra gear.
Say I’m blocking down a leany spar and there’s no limbs where I need to make a cut, to make things worse it’s pretty leany and getting a nice face into isn’t going to much fun fighting the lean. I need a second tie in, it needs to be cinching, and I need to be able to descend straight to the ground in case something goes wrong. MRS, I would need extra gear, some sort of adjustable friction saver. But that has limitations because it may not be large enough and it’s probably not going to help me get stable on the leany spar.
SRS this becomes an easier and quicker problem to solve. I pull out some slack from my hitch climber, I throw the anchor end around the spar and I tie off a suitable running knot, I take the spare carabiner off my hitch climber and put a munter below the hitch climber. I can work off it, I can lean against the bight on the anchor end and get comfortable on the side of the lean, and I can descend if needed. Some variations on this make it just as easy to retrieve.
