Critical Incident Report of Rope Runner Aug, 2020
I had been using the Rope Runner Pro almost on a daily basis since purchasing it from TreeStuff in early July. I was new to the rope runner and was anxious to use it and get used to the features that others have given rave reviews.
In August, I was about 50 feet into a tree. I was coming down rather fast when all of a sudden I heard two clicks and I began to drop like a rock. Fortunately, I had my left hand below the rope runner on the rope letting it feather through my hand. I grab the rope both above and below the rope runner slowing my fall to the ground.
I looked at the rope runner and realized that the only friction on the rope was held by the bird at the top. Not having a lot of time to evaluate what was happening I essentially let the rope go through my hands as I tightened to increase the tension on the rope and slowing my ascent. The gloves were burning as the rope slipped through the gloves.
Fortunately, I made the hard drop to the ground with no injuries. It did shake me up.
Looking at the rope runner upon the ground, I realized that the two lower slic link pins were not pushed into the plate that catches the pins. I could not figure out how they came out. I have been using the rope runner for nearly a month, I never had forgotten to push the pins all the way in before. I usually start from the top or the bottom and as I go, I push the pins in once the rope is in. I had no problem ascending the tree. The rope runner held me in place when I stopped to rest or evaluate the cat rescue that I was involved in.
I was up in the tree for about 45 minutes using the rope runner to secure me on the rope. I was lanyard-ed in, but the Rope Runner did most of the work to keep me in the tree. I did not notice anything wrong with the rope runner.
In the descent, I was probably coming down faster than I ever had, just to test my skills in descending with the rope runner, which is not fast compared to my colleagues. It was in this descent, that the rope came out of the rope runner and all I had to secure me was the slight drag created by the bird and my two gloved hands.
I report this as a "critical incident" because others need to know that just because the RRP holds on the ground or in the tree does not mean everything is correct. In other tree climbing situations, this incident could have been catastrophic for me.
I stopped using the Rope Runner Pro from that incident. I had no confidence in it.
