If the tree is being topped (and ignoring the 'topping discussion') and material needs to come down on ropes, the best way is a speedline. That way you are just sending material out and over the limbs you want to keep rather than risking the hassle of hanging up brush, or breaking what you intended to save. If you don't need to lower/rope anything, either climb high and cut/toss small pieces, or strip a section of the trunk above your intended final height, about as high as the longest branches, then drop a big top from the bottom of the gap you made. That way only a bare trunk is brushing through the limbs you want to save, reducing/eliminating breakage of what you want to save. Obviously you have to be comfortable taking pretty big tops and have the space to do it for this method.
