rope-a-dope
- Asheville
Yes, we typically will ride the ball anytime we can, including out over the limbs to be rigged. This will usually get you as far out on those limbs as you want for tying slings. We use a bunch of rope "spider legs" for anything brushy or limb like, even leaning wood chucks.
Multiple rope slings help balance the pick by applying even tension thru the whole shape. You put in a little extra work ahead of time so when you cut, there is no flailing, no lifting, no breaking a snap cut, no twisting, rolling or pinching. Most crane picks I do are cut straight thru, with a slow down at the end to see if I need to finish from a specific side to avoid compression. Dynamic crane picks give me the willies, so I rig things very carefully.
