When you cut limbs (solar collectors) out of a crown, does the the tree do nothing in response?
If you strip out the interior of the crown, does the tree do nothing in response?
Does the tree grow more foliage on the remaining ends of the limbs?
Do the remaining limbs grow larger and heavier in, let's say doug-fir with limbs that blow off when too end-heavy or over-long?
Is the climber really good are reading the mind of the tree to know which limbs are the problematic ones, having defects, rather than leaving defectively limbs more exposed?
Doug-fir commonly get neutral-plane fractures in over-extended limbs. They can remain growing at times. Expose them to more wind, and lion-tail them, hmmm.
Scott Baker (can't @ scott... atm, recent recipient of some sort of ISA Lifetime Achievement Award), said that in the 70's and/ or 80's they welded to the bars so the bars were wider than chains, allowing them to 'skin out; the firs, from spurs. Also, slaps his head about topping maples down here in Olympia, because at the time, it was the thing.
Does anyone know of any research that suggests wind-lacing is good?
So is there spur-climbing, wind-thinning in a video titled (disparagingly??) No, I won't top your trees?
