Getting back from a limb walk.
Levi, your tape mark is in the wrong spot. It needs to be at the BDB. Then you will have 6 feet as it is a 3:1 system.
Dave, I disagree, it's about how much moves through the pulley. At least in the mind of this high school drop out.
By that logic, if I were to pull on my tail up from bellow my system 180° I would have a 2:1 ma however, this is not the case.
Mechanical advantage in order- 2, 3, 4, 5, 6
http://www.technologystudent.com/gears1/pulley7.htm
So what are you trying to say? That our DdRT is a 1:1 with no mechanical advantage? Block and tackle charts are calculated from a different perspective.
Stop looking for answers in charts and put your harness on. Set a single leg of rope, grab hold and pull yourself up. That is 1:1. Feel it? Now a DdRT system and pull. Different right? Now set a haul back and do the same. Different still. Don't think just feel it.
The climber is the load. The same legs of rope are being pulled on. I don't see how this changes the math.
It doesn't.
Earlier you said that the tape in the video I posted was in the wrong place. Do you still make that claim? Clearly it is false.
