If you have both types, when do you change between? When you loose traction, or do you make a perfect decision every time before you leave the ground?
Hi Graeme
Depends on the tree, if it's thin barked like Chinese Elm, Leopard trees etc I take the shorts, if it's like Pine or Ironbark etc I take the longs ... if in doubt take the longs.
Sometimes with species that have a sock like Blackbutt or Flooded gum you need the longs to get past the sock but shorts will do the trick once you are in the canopy .... so instances like this I assess whether or not I have to block down the sock ... if so, take the longs, if not and the barrel can be felled then I take the shorts ... of course a high lines in to get past the sock.
I wonder why they don't make a medium? I have Bashlin climbers and the difference between the short and long gaff is huge ... the only place a completely bury a long gaff on those Bashlins is in the crown of a palm.
Anyway, a few fans have been asking if you sell your DVD's yet? Last I saw your vids was GreenX Sydney 2003, have you any new material?
