Re: Stay From Modern Equipment and Bandit Chippers!
It sounds like you got a lemon.
The winch running backwards should have been a quick fix done by your crew right on the job site. Just the hoses reversed. Lots of machines won't lift the feedwheels at idle due to how hydraulic systems work.
Almost all heavy machinery needs constant observance by experienced operators or else you are going to end up with very large maintinance cost.
Get the issues fixed that you have found and be happy with the chipper. Bandit is a good company and makes a quality product.
Sounds like someone didn't read the owners manual, and spooled the winch backwards. If you pull the cable all the way out whichever way you throw the lever is in.
