Hi,
sorry in advance, this is boring stuff.
I have been getting some size questions about the HAAS. and what can be expected as far as performance . what I have tried to do is taken one of my formula charts and color coded it and I tried to simplified it. my hope is you can look at the chart, take your measurement of "boot to hitch", and figure out what size you need, and how much of a step you can expect, I used the limiting step to make it simpler. this should also provide a good estimate of where you should tie on you boat snap…. elongation formulas are tricky and hard to show… does this work at all? or is it stupid confusing? my head hurts from this stuff, and it no longer makes any sense to me.
really my question is this a format that works?
Red is the regular Size,
Blue is the Long size,
Purple is overlap of Size. where either will work.
and and all thoughts are welcome?
I could to a input field and it returns the info. you put in 34 and you get back a reg haas, 13.3inch step and tie your boat snap so at rest the there is about 3.5 inches of exposed bungie.
is this preferred?
is this preferred?
