I do have a biege dog, but I wouldn't be taking her to the states unless to live! Spooky!
There are many saddles that allow the frog system. But only the Petzl variobelt with sidestraps, and TreeFlex, also have sliding D for work positioning.
I would avoid any saddle with a very large back pad, designed to sit in the small of your back. There are many accounts in rope access and tree work, of lower back complaints. If each component of your spine cannot flex - you are going to alter the (4) natural curves of your spine. That leads to injury. One reason being, that if your spine doesn't flex, the body stops providing synovial fluid for lubrication. No prizes for guessing the risks there!
This is why we designed treeFlex - a true ergonomic design to fit the pelvis, not the lower back. Its comfy leaning into a flipline or work positioning, and doesn't restrict natural movements. The design is an internationally licenced idea (like copyright) and has an adjustment system patent pending. We have an anatomy programme that strips the body down in 3D through its various layers of muscles, nerves, ligaments, tendons and bones (gruesome but cool!). The TreeFlex is designed to fit the pelvic girdle, resting on the fused bones of the sacrum, the muscles of the Gluteus maximus (ideal at carrying load), whilst cut away to allow free range of hip movement and avoid pressure on nerve lines. The design prevents the belt from riding up into the ribs, and is cut away there also. The rear pad sits in the sacrum hollow (especially with chainsaw clipped centre back). This helps keep the harness seated properly. The waist belt tie-in is low down like a caving harness for slick frog SRT - karabiner loop, no D. The lighweight 'Y' chest harness, can be unclipped front and back, so its quick to leave it on the access line after ascent if so wished, or removed completely and quickly for jobs where it isn't required. I just wrap it round my waist and keep it with me most of the time.
Initially, I thought it wise to advise all to wear any harness below their hips. But we know of no harness ergonomically designed to do that (apart from TreeFlex). Without the cut aways etc, they can distribute pressure in undesirable ways, and not support or function in a technical way.
Hence TreeFlex - the solution. The harness has many unique features, and is designed and protected in such a way as to have no equal
Its a great product with a collaboration of cross industry experts - real ergonomics and systems engineering, that will benefit ALL harness users eventually.
I think I'd better shut up now! I haven't posted pics, because I'm waiting for the polished version with final colourings and fittings. That should arrive in the next two weeks, so I'll post the pics in the 'TreeFlex' thread then.
Sorry this went on a bit.
