LTB: rope wrench slic pin zk-2
Christrees
Been here a while
New York
Does anyone of there have an extra slic pin for the rope wrench? I bought the rope wrench that was on here and theres something wrong with the slic pin. Its barley rolling? Idk why. Treestuff has 3 week back order. Ill pay you for it.
I'll look. I know I had one for the ZK-1 but not sure if that one will fit. Measure yours for me. If I can find it and it fits, it's yours.
I don’t think it is suppose to, the rope creates friction by running over it, there wouldn’t be as much if it acted like a pulley.
When i pull down on the hitch it doesn't move at all unless. I pull down the wrench. Im pretty sure its the slic pin. Its been awhile since I had 1 also. But i think im right. Could be wrong
I know I have one for a zk2 and maybe for a zk1.. issue is that I want to keep them as backups. If your in a pinch and kick down a few bucks for shipping I’ll send you my backup and you can order me a replacement.
Yeah i understand. I want to try and make it so i dont have to put an order in anytime soon. Ive spent like 600 just this last week on gear. And moneys starting to get tight. I mean id put an order in eventually but not for a month or 2. Im the same way id get a backup too. Unless i order $100 it would cost me like $50 for $12-15 for 2 slic pins. I couldn't find any on ebay yet either
I cant find my tape messsure so i took a pic of it on a small steel ring? Probably dosen't help just tried to think of something youd have.
X2
You think the pin is a little bit too fat then?
A little sandpaper should do the trick if that’s the case.
Maybe..or a little course or something cant think of the word. I was moving the wrench up and down with the hitch affecting it. And the pin would roll then stick. Roll stick. That may help. Worth a try. I have to pick some up thats gotta be pretty fine.
That pin has some nice wear. You good.
Ok cool thanks..its been awhile. Ill put a pic up when i can i think its a 4/1 michocan. And i haven't had it in the tree yet. I was trying it just by hand. So thats probably part of the problem. It was -20ish with wind chill. But ill take it outside quickly tomorrow.
