Oh didn't see you there Steve.. What about the Regular Goop? That link seems to have 70 pages supporting it.. (70 on Tapatalk)You'd be better off with olive oil to get sap off, then wash with dish soap. At least you know it wont hurt the rope. Myself, just soak in tub overnight with a smidgen of Sunlight detergent, works like a charm.
Just to be clear on the oil thing, I personally don't do it, I do know others that have spot treated with olive oil and immediately rinsed with soapy water until all residue is gone. This only if a rope is dragged through a pool of sap. I don't see this as a big deal if attention to cleaning is payed. Soap isn't even needed in the tub method, but a small amount won't hurt. Realistically, you will hour out a rope before these methods will adversely effect it. I don't mess around with trying to maintain ropes, I just replace em and give people cut up ropes for utility tie downs etc.Tom.. that link contains the same thread as posted at the top.. that & one other short thread containing mostly the 2 step oil & detergent method..
I didn't start this thread but i am curious now as to why one would want to use the more labor intensive method over the Goop method.. It literally took longer for my shitty hot water to heat up, than it did to get that rope clean.. the sap just came right off, barley any elbow grease or soaking times involved.
Now i will say, this is all assuming that it's ok to use.. however, theres 70 pages of opinions supporting it within the link everyone keeps posting.. I understand it's been discussed but this its like... Someone asks a question, instead of a yes, no, or idk, a link gets posted, I follow direction from posted link with a newer similar product from same family, i ask if anyone knows about it having phosphates & the same original link gets posted as an answer..
With the exception of Steves & Levi's answer, no one seems to want to talk about it. But then on the flip, the main method Steve is suggesting, is what the original linked thread is suggesting to avoid. In this larger linked thread, there are two reasons not to, it takes way longer & some have reported having an oily rope after. So it seems to me it's a YMMV type of deal. I'm also asking about phosphates as they were mentioned in the links posted with no further explanation as to why not.. just to avoid.. I'm also pretty sure phosphates are very common in allot of cleaning products & detergents.
Aside from the phosphates, I'm also just timid to do anything that could create an oiled rope. I remember the first time i threw on a pair of spikes, it was a hectic day & someone had forgotten the one saw lanyard we happen to have that day. I tied up some sort of contraption with a real short peice if rope that just happen to be previously soaked in bar oil. As soon as i cinched the knots down it must have squeezed oil out of the rope.. on my second cut about 20-30ft up i just dropped the saw to move on.. i felt the jolt of the saw, but then heard a bunch of yelling.. the knots had completely pulled/slid through themselves & the saw was on the ground.. No.. i didn't have stoppers in there but i can't say they wouldn't have done the same. When i came down it was evident the areas i knotted were drenched in oil. Either way I've never forgotten that embarrassing/dangerous experience & can't help but relate the two when I hear about purposly putting oil on a rope.. i can't help but think it's going to soak into the core where you can't agitate it out, nor is it designed in any way to rinse away with water. Your counting on your Dawn or Detergent (which could also be just a bad as a harsh cleaner depending on its makeup) to seep into the ropes core & remove the oils that got in it. The way i see that is, try washing you car without a brush.. pour oil on your hood, cover it with a towel let it seep in. Pour your soap on towel & rinse till you got no more suds coming off towel.. sit back let it all dry. When it is dry, pull towel off & i garantee it's still had oil in it, but further more, that oil spot under the towel is still there..
Yeah that may not be an apples to apples comparison but it was the easiest way i could think of explaining my concern. Now if you could get some swishing & swashing agitation from a washing machine, i think that would be helpful, but personally I'd want multiple rinse cycles.
Lastly, as with most stuff these days, there's an internet forum for everything.. I know that automotive detailers treat their microfiber towels like most here with their lifelines. When they get dirty it's all about not destroying the fibers' absorbing & grabbing capabilities with typical detergents.. & typical detergents will do just that, destroy their integrity. Because of this, there's a gazillion different types of professional microfiber washes. I was just thinking that if they are safe for the precious super sensitive microfiber towels they may be safe for rope.. I know allot of the harsh chemicals we all should have a mental note about, are removed from the dedicated cleaners.. They'll also remove tar, grease, oil, wax, rubbing compounds, etc from the towels pretty well. Couple cap fulls to each load & shit comes in gallons of u want.
Just fyi.. I'm not trying to debate anyone about the oil method. Im only voicing my concern & last experience with oil & rope. & To be honest, I'd really like to know more about the product i used because it worked so damn easy.
Tom, you know those mesh bags that the army issues all soldiers with for their laundry? Ive used those in the wash machine with ropes, that works really well too, they can be found at Army Navy surplus stores easy!You seem to have answered your own question
My career started with natural fiber ropes. If they were dirty it must be time to replace. Now, after a long career and reading lots of books, talking with experts from rope manufacturers and , like you now, using forums...same conclusion. Wash with soap...not detergents. Nothing too complex
If phospshates are a concern and us amatuer rope care 'experts' aren't the experts...go retro. On Monday give a call to your favorite rope maker or two. Ask them live. Then let us know
I'll wash mine in a top loader using some appropriate soap
And will continue to work so long as your top loader does!There's a chemical misunderstanding because of the use of 'oil' to refer to petro oil as well as veggie oil. I remember just enough from
Chem 101 in 1972 to know that they are much different. Soap is a close chemical cousin to soap. One of The cleaning mechanisms is the breaking off of ionic bonds between the rope and the dirt. Chemical magnetism and all
When it's rope washing time I hose off the big stuff in the driveway. Then I quarter the rope and make loose daisy chains. Secure the ends and loosely coil it into my top loader. Large load, long cycle, add soap and that's it. Worked fine for decades
