New Toro Tx 1000 Wide Track
OasisTree
Central Missouri
We have had our machine for about a month now, and it has 45 hrs. on the meter. So thought I would give all my friends at Treebuzz a little info about whats to like and whats not to like about the machine.
1st of all, it is a complete redesign of the earlier models. It is red and black and has the Toro sticker, but that is where the comparisons end. I am replacing a Toro TX525, so all comparisons will be to that machine.
Ride comfort - with the new triangle track design, and larger road wheels, the drive system is much smoother. The track adjustment is the same, but it is easier to see if it is adjusted right.
The electronic T handle is a one-handed drive, and forward and reverse speeds are the same at 4.7 mph. They did limit the flow when turning, so full speed is only while going straight. Somehow you can go faster with lower RPMs, not sure how that works.
The aux. hydraulic lever is now in the middle of the instrument panel, and is much shorter. We noticed right away that it was not intuitive. To open the grapple you have to pull back toward you. So we switched the hoses on our grapple so it made sense.
11.5 gal. fuel capacity, with 2 tanks to fill. There is not an option to switch tanks.
The platform is tilted forward, and rests against large rubber bumpers, which helps out with ride comfort. Machine also has 6" of ground clearance.
Maintenance access is much better, which will make it easier to work on.
The parking brake has been moved off the instrument panel to down by your feet.
I love the vertical lift. It keeps the load close to the machine as you raise it, which is a big deal when loading large loads onto a trailer.
Loader has more reach, has been redesigned for better view to attachment, and the cylinder that tilts the attachment is larger. Thicker steel was also used for the loader structure.
Overall very happy with machine. I feel it is the step in between a traditional mini, and a track skid loader. Machine is very smooth and stable. Have no complaints with the 25 horse engine, the benefits being no emission requirements. The hydraulic pump is upsized to 15 gal per min.
Beings this is a redesign, there are some issues to work out. Here are the ones we have had -
Defective hydraulic hose - blew at 10 hrs. Covered by warrantee.
Hydraulic hose connections on pump not properly tightened - 2 separate fittings worked loose, made a mess.
Front cover was not designed correctly - rattles against hydraulic pump. Toro told me to grind it back, which we did. We also added washers onto the bolts that hold the cover on.
Hydraulic oil runs out of breather - breather on hydraulic tank is mounted right on top of tank, which is on the bottom of machine. Not an issue on level ground, but that's not the case for most of us. Toro has come out with a kit that raises it about 15 inches. Installed kit yesterday, I think it will work much better.
Electronic sensor on park brake - When park brake is on, it renders the drive system inoperable. Once again, not an issue on flat ground. But if you park on a hill, you need to reverse the drive wheels to release the pin. We ended up breaking a park brake cable, which was covered under warrantee. Toro is working on putting a 5 second delay on the drive system, so that wouldn't be an issue. We moved our sensor out of the way so it wont ever come on. The only reason for it is so you have an indicator light on the dash when it is on.
Here are some pics - note the comparisons
IMG_20160208_093142591_TOP-1024x576.webp IMG_20160208_091500737-576x1024.webp IMG_20160208_091441501-1024x576.webp IMG_20160208_091632736-576x1024.webp IMG_20160208_091644570-576x1024.webp IMG_20160208_093259395-1024x576.webp IMG_20160208_093342934-1024x576.webp IMG_20160208_093348037-576x1024.webp IMG_20160208_093406225-1024x576.webp
I like it. I also have been running a 525 tx for years and have been wondering WHEN they were gonna put out a new gen. model. Looks much heavier. Also looks like you get a good height reach but the outward reach (where I want the improvement into a dumptrailer etc.) has not been increased or is there just an overall radius increase.?
I think it is too cool that you switched hoses and fixed the problem that nerd engineers likely had no clue about.
The outward reach seems to be some better, and the extra height really helps when loading the dump trailer with the bucket. I guess the answer for more forward reach is to get a forward tip bucket.
Sent from my XT1097 using Tapatalk
The outward reach seems to be some better, and the extra height really helps when loading the dump trailer with the bucket. I guess the answer for more forward reach is to get a forward reach bucket.
99 percent of my usage is grapple. I have the Dingo front grapple, not the cheaper aftermarket ones. That is where I need more reach.
But I have numerous other attachments.
I called my dealer and they are gonna call back to give me a demo day.
I have the 4' rake grapple from Anbo, which actually makes the grapples for Toro. Has 4' opening, and we love it.
I will buy your 525 if the price is right! Unless your looking to keep it and run two? And by price is right I mean under 5K:)
Again, hope my implements cross over. I love my grapple, power angle snow plow, high torque big head auger and bits, tree ball squeezer (ouch), 2 buckets, plate to put ball or pintel hitch on.
Probably would seem odd to ride that high off the ground. The 525tx works because it floats (the surrey). Bet it plows better than my current unit, and it plows snow real well.
Just noticed you put "same attachment plate". Thanks.
Are you keeping both. If I did one would sit around all the time I think. I had a Bobcat MT 50 for a while and thought it would be good in the wood pile full time but the Dingo always came out as nobody liked it.
No my other one was sold before I picked my new one up! I guess I was using the old one too hard, it kept giving us fits.
