Thanks to Treebuzz help, I easily took care of this hanging dead limb.
Winchman
A twenty-four foot limb hanging by a thread sixty feet up. The tree is only several feet from the house and heat pump.
I found a good crotch on the opposite side, and got a line in it with one shot. I was confident I could climb past the lower part of the limb without touching it, and get high enough to make the cut at the very end.
Since I didn't know the weight of the limb, I carried two ropes up with me. One was anchored to a nearby tree, and it was set up so I could use it to lower the limb from the ground. The other rope was loose so I could use it to lower the limb from up in the tree if it wasn't too heavy.
I tied the anchored rope to the limb, and made the cut. After checking the weight of the limb, I used the other rope to lower it without any problem.
Just enough, but not by much.
That'll ease the worries of the elderly couple that live there, and I probably saved them enough for a nice Thanksgiving dinner, too.
