Larger Chainsaw Advice
slowturtle67
Melbourne
Hi Everyone,
Looking to make my life easier
I've got an 2511t and a 394xp
I run a 14" bar on the 2511t
32" and 20" bar on the 394xp
I've been using the 394xp with the 20" bar in the tree and it's too heavy.
Looking at getting a larger saw and bar combination that is as light as possible.
Which bigger saw 50-70cc has the best power tow weight ratio?
What is the lightest bar?
Simpleiowaguy
Vinton
I like having a range. I run all husky. My go- to for bucking wood in the tree is a 550xp with 18" bar. Other saws are T435 w/ 14", a couple 455 ranchers with 20" for the ground guys, 372 w/ 24", and 395 w/ 32".
rico
redwoods
Depending on type of wood you are working with-
550XP with 18" - 20" bar
562XP with 20" - 28" bar
572XP with 28" - 32" bar
395XP with 32" - 42" bar
Sugihara lightweight bars are highly recommended for 36" bars and below...
All of these saws simply kick ass in bone stock form, have a great power to weight ratio, and a combination of chain speed and low end grunt thats tough to beat.
Christrees
New York
What about a 462 with a 30 to 38 inch bar. I love the 462s. Great saw. Nice and light for a big saw. Can put a decent size bar on em. I can only gives insight on sthils that all I've ever ran.
evo
My Island, WA
I'm pretty fond of my 261... Dont know huskies much.. But go from my ms020 or 150 modded to a 261 or 361 with 18 and 20" respectively. I'm OCD with running 3/8 .050 on all my saws over top handles... so the 261 is kinda off spec but runs just fine with a 18"
swingdude
De' Island Buzzer
Barbados
Geez.....wish we had good husqy support here. Well I been wanting a few for ages. Need to honor that. Erik you might have to be my parts man.
Jehinten
Evansville
I'm not sure the actual power to weight compared to others, but a woods modded 261 is fun to run. Very lightweight and lots of power for a 50cc saw. My MMWS 261 came with a 18" bar, it could easily run a longer bar if you wanted. I'll likely put a 20" on it, as that's what I'm used to stepping up to after trading out my 200t with a 16" bar.
After that I go up to a 661 with 36" bar.
dsptech
North East
I have the 620p as well and I love it, can run a 28" bar with a full skip on it.
I run a Husqy 390xp for larger wood up to 42" bar.
I'm thinking on buying the new Echo cs-490 as a lighter saw for in the tree rear handle to replace my cs-400.
Check it out here... Echo CS-490
climbingmonkey24
United States
I’ve got a CS-400 too, that was the first saw I ever bought as a matter of fact before I started doing tree work professionally. Great “in between” saw in the middle of a lighter duty top handle and the heavier duty bigger saw.
