Carlton SP4012 belt tension question
MA Arborist
Cape Cod
I am having trouble with my machine. Just replaced the drive belt (not the poly chain).
The problem I am having is that the belt is turning the cutting wheel even when it’s not engaged. This is happening even with the turn buckle in the engagement lever turned down. Basically it turns the cutting wheel even when loose
Any help is appreciated !
MA Arborist
Cape Cod
Mine does that. I always assumed that it was because it had been modified for an engine swap.
Interesting...i had just changed the belt after almost 900 hours.
The replacement belt is an exact match to the original but the original didn’t cause the problem with the wheel spinning when disengaged. I took the cover off again and looked everything over but I cannot figure out how to fix this.
Obviously I must have done something wrong when I put on the new belt
treegongfu
Pretty hard to put it on wrong. There are adjustments to tighten it up, I assume you know this and have tried loosening it a bit.
MA Arborist
Cape Cod
My mechanic was over today. He suggested that the sheaves/pulleys may be worn causing the v belt to sit too low.
I will be replacing the sheaves/pulleys. This machine has close to 1000 hours on it
