Arborjet taking in air at needle
Jzack605
Long island
One of my kits randomly started pulling air in through the needle when the plunger loads back again, kind of like a back flow. It has quick connects for the lines and I cut those and reattached on the line from the plunger to the needle but that didn’t work. Any other solutions?
Gus64
Are you using the QuikJet Air kit/injector?
Gus64
In my experience using this it could be a couple of things--see attached pic. Sometimes I need to replace or at least clean them out.
Jzack605
Long island
The needle was also swapped out. I’ll try all of these suggestions hopefully tomorrow. The unit was clean but did about 200-300 injections in the past week before the issue.
Gus64
Yes, regarding the in-line check valve, #70-2366: I notice that the ends of the tubing that are inserted in it need to be sharply, cleanly cut so there's a good seal inside the valve. As the line gets pulled it sometimes gets yanked from inside the check valve and thus air gets in and won't pump the product through.
These units work great but can be finicky.
