Air Knife or Air Spade ?
JeffL
Orange, MA
Air knife, no competition.
Moves a ton of material, and if thats not your goal that day, turn down the pressure. Does double duty!
NickfromWI
Los Angeles, CA
I couldn't tell what the difference was. I ended up with the Air Spade because that was the first one I had ever heard of, so I assumed it was better.
So what's the diff?
rfwoodvt
If I understand correctly the Air knife came first.
Both operate with a DeLaval nozzle to accellerate the air stream to supersonic at the exit. Really, it is rocket science albeit real basic.
Airspade has gone a long way towards making everything custom for the tool from the wand to the valving to the nozzle whereas AirKnife uses a lot of standard off-shelf components.
The only thing I have truly found unique is the patent for the Airspade, It is interesting to note that it appears to be more of a process patent versus a device patent. What is the difference? One protects the device, the other protects the process under which one builds the device.
I'm no patent law attorney so I may have missed something, but I gathered the essence of the AS patent is the methods on how to cnc machine the nozzle in the complex profile they believe to provide the smoothest, less turbulent side flow of the airstream.
Both nozzles accelerate the air to supersonic. Both try to straighten and contain the stream for the first few inches out of the nozzles.
And, both nozzles are fixed-parameter, in that ambient temp, barometric pressure, compressed air temp, flow and pressure may change but the nozzle cannot adapt to those changes. Therefore, you will seldom, if ever, get the perfect air stream from either one on any given day.
In the end I went with the AK for a couple basic reasons. <ul type="square">[*]First, price. AK parts are about half those of the AS. [*]Second, off shelf components. [*]Third, you can still talk to one of the people involve in the initial designing. [/list]
JeffL
Orange, MA
We have both. Running them back to back the difference is undeniable. The airspade is a honda accord. The airknife is a top fuel dragster.
cambmx
Member
Wisconsin
You can make one that works at least as well as both for like 50 bucks, why does everyone spend so much on them? I haven't found anything different other than how it looks so far, just curious.
ATH
Ohio
I own/use Air knife. I have used an Air Spade a couple of times. The angled handle and/or nozzle seem like a good idea, but actually using it, I find being right above the tool with the handle and 90 degrees and straight nozzle is less tiring on the arms/easier to control.
Air Spade certainly markets to our industry quite a bit more...
ATH
Ohio
I bought mine from Dave back in 06 (I think). I called and said "if I buy one from you, can I come spend a day with you learning how you guys use it"?
evo
My Island, WA
There are also a few others who make basically the same tool but marketed to different industries. Airlance is another..
ATH
Ohio
Anyone know of a place to get lightweight 1" air hose for a better deal than $280 for 50 ft??
I can't find the exact hose I have, but it is pretty close to this:
I know...it is rated for water, not air. I have used it for hundreds of hours with no problems. I also tried 1" regular fire hose and blew the ends off of that, so don't try that.
You can get the Chicago fittings at McMaster Carr to thread onto that hose.
macrocarpa
Midwest
I bought the air knife from Dave a while back and have been very happy with the tool and his available guidance. I'm in the market for a used compressor if anyone has any advice? I would sell and save a lot more trees if I didn't have to rent a compressor. So many trees need root flares exposed! + dig holes for planting.
