Tension vs compression
Discussion in 'Crane Use' started by Phil, Jan 10, 2011.
  1. Phil
    Phil Member
    May 3, 2005
    682
    Oak Lawn, IL
    I took this from another post so as not to derail it.
    Engineers use it (wood being 5x stronger in tension) as design guide when designing wood structures. Its 5 times stronger when you are pulling on it than if you are pushing on it or trying to put pressure in the middle.
    On construction sites contractors have had us try to lift a single 2"x4" out of concrete and we lifted 3000# on it and it didn't budge.
    if you bend a straight branch (or 2x4) in to a "U" shape you create tension wood on the outside of the bend and compression wood on the inside of the bend. When the branch finally brakes, it brakes the tension wood first. So does this mean compression wood is even stronger than tension wood?
    Is there anyone that can take a 2x4x6" and pull it apart and take the same size piece and try to crush it? I'm just curious.
  2. SingleJack
    SingleJack Active Member
    Dec 11, 2009
    698
    W MD
    The following PDF link to the USDA, Forest Service, Forest Product Lab may be helpful:
    Wood: Strength and Stiffness
    The data in Table 2 appears to conflict with the "5 times stronger" statement. And, as with everything else in tree work, compression vs. tensile strength is very species dependent.
    Treetopflyer likes this.
  3. Jamin_Mayer
    Jamin_Mayer Active Member
    Apr 10, 2005
    5,706
    Longmont, CO
    Nice link.
    We should get C.E.U.'s for reading all of that. [​IMG]
    SingleJack likes this.
  4. classictruckman
    classictruckman Well-Known Member
    Feb 16, 2009
    2,622
    Ottawa Valley, Ontario, Canada
    According to that table wood is generally 2x stronger in tension than compression and almost 10x stronger than shear force. And bending is almost as strong as tension force.
  5. SingleJack
    Dec 11, 2009
    698
    W MD
    FWIW - A note of caution about tensile loading of wood
    <u>Just in case</u> there is some intent by the OP (or anyone) to use wood as a structural element under tension, it should be noted that joint design and attachment method are critical. A poorly designed wooden attachment will fail in compression or shear long before maximum tensile strength is realized. It is 'old-world' technology so there are many excellent reference sources available.
  6. classictruckman
    Feb 16, 2009
    2,622
    That is very true, structural flaws will cause failure long before you reach the tensile strength of the wood.
Share This Page
