Stihl ms 290 Farm Boss questions
#1
Hi folks. So I have the saw in the title, I know it is a “cute” saw, but until I can get a 461 it will have to do.
I rebuilt the carb today and replaced the spark plug. The saw ran like a champ while cutting my notch and then died as soon as I started the back cut. I let the saw sit, it cooled off and started great. Rinse and repeat. Now it will not start at all. I ended up finishing the job with my friends ms 170.
I am using a fresh ethanol free gas mixed with the Stihl oil.
Any tips or tricks? Swearing at the saw did not work.
Jehinten
#2
I own a 290, its actually the first stihl I ever owned, given to me by my Grandpa years ago. It's a little over 30 years old today.
Any time you work on something and then a new problem occurs it's almost always tied to what you were working on. It's most likely caused by your carb and could simply be carb adjustments.
#4
Thanks guys! I reread my post and realized I left out the reason why I rebuilt the carb. I ran some True Fuel through the saw, one tank, and when it went dry I put ethanol free gas in it and the saw would not start. My local saw shop recommended the carb rebuild and spark plug replace to fix. It worked until the problems above. Once the saw warms up it just quits. I really like this saw. It is the first chainsaw I ever used. I’ll check spark and my carb work to see if I did anything wrong. I really appreciate the tips guys!
#5
Hi folks. I have spark and checked my carb work. Both are fine. I screwed both the H an L screws clockwise till the seated and then backed the L screw out 1/4 turn CCW and the H screw out 3/4 turn CCW. No joy on either full choke, 1/2 choke or no choke. Very stumped. Any ideas?
#6
Not familiar with that saws specs (maybe someone with more knowledge can chime in), but most saws the high and low both back out about 3/4 turn as a starting point, I would try that first.
Also are you sure the impulse line is attached and that the fuel line is not obstructed in some way?
To check if its fuel related (pull the chain for safety) and then add a little fuel to the carbs throat and hold the throttle open and pull the cord till it starts revs up high and dies....if it will not start by adding fuel to the engine manually then its not a fuel delivery issue.
#7
Thanks! I will try that on Saturday (my next day off). I appreciate it!
