Electric brakes on the chipper
Discussion in 'Rubber hits the road!' started by Tom Dunlap, Dec 7, 2017.
  1. Tom Dunlap
    Tom Dunlap Administrator
    Jun 1, 2001
    14,514
    Moved to Minneapolis
    im not very familiar with electric brakes.
    When I've seen a factory installation a small battery is included with a trickle charger. It would seem that the only time the battery power is needed is if the break away is triggered. Am I missing something?
    If that's so why couldn't the chipper battery be used? This would simplify the setup. Worse case , it seems, is that the chipper battery is drained
  2. tc262
    tc262 Well-Known Member
    Feb 17, 2015
    1,178
    SE Wisconsin
    You're correct Tom. Battery is only to actuate the brakes if the break-away is pulled. I haven't seen any thing that has its own battery also have a small one just for the brakes.
  3. Bucknut
    Bucknut Well-Known Member
    Jun 1, 2010
    484
    I'll second that. Our trailers have small dedicated brake batteries, chippers do not.
  4. craneguy1
    craneguy1 Well-Known Member
    Mar 6, 2005
    909
    USA
    Any trailer with electric brakes sold nowadays also has to have the breakaway...using a cute lil battery...chippers have their own battery and when sold new have to have a breakaway and do use the units battery. The biotch comes when wires or that crappy plastic pullout plug mess up and lock up the tires...now you just screwed up $500 or 1000 worth of tires.
    Tom Dunlap likes this.
  5. Merle Nelson
    Merle Nelson Well-Known Member
    Mar 24, 2012
    1,446
    SF Bay Area, CA
    Also have heard of crews pulling the plastic tab so the brakes are set for sitting there during a job.
    Battery drained and probably hard on those braking actuators to be in the always on position - oops.
  6. Tom Dunlap
    Jun 1, 2001
    14,514
    That's a bad practice for lots of reasons
    Has anyone knot cut up a log to make a nice tapered wheel chock?
  7. Jeff
    Jeff Well-Known Member
    Mar 27, 2007
    1,096
    Marlborough, MA
    Isn't that why we cut those so-called Felling Notches?
Share This Page
