Can anyone help me diagnose what wrong with this red maple?
Discussion in 'Pesticides and Ferts' started by JoshR, Apr 16, 2017.
  1. JoshR
    JoshR Active Member
    Jan 17, 2015
    150
    Alabama
    Not sure if this is the best section on the forum but here 'goes anyways. I planted this several years ago and has been healthy until last year. I built my porch 2 years ago and I think I cut a root when I was digging the hole for the posts. Oops! Well anyways, I don't know if that would have caused these problems or not. My guess is yes but then as I said, I'm not sure. I had a little bit of dieback last year and a more significant amount this spring when it bloomed out. Also, I tied it over for about a year and a half in an attempt to train the new growth in an direction away from the roof.
  2. JD3000
    JD3000 Well-Known Member
    Aug 28, 2016
    4,045
    Columbus
    Doesn't look too promising. Not much if any reaction to pruning wounds. Looks like it may have been mulched too deeply. Root loss from construction probably not helping.
    Start over in a better location?
    JoshR likes this.
  3. arborcareman
    arborcareman Active Member
    Jun 25, 2009
    337
    ILLinois
    Too close to the structure anyhow. Start over.
  4. colb
    colb Well-Known Member
    Jun 12, 2014
    760
    Florida
    Maybe hire a local arborist to look at it? Pictures are great, but tough too...
    I don't see a root flair - why?
    Is the root ball surface above, below, or level with the adjacent landscape horizon?
    The pruning cuts are okay overall, and at least a couple were "enthusiastic" ;) - not bad for a homeowner.
    It looks like the tree, above ground and below, has no targets. Time is on your side. Keep bending that tip, or prune it to similar effect.
    Would there have been freeze damage, herbicide treatments to the grass, or changes in watering regimen? Has there been *any* change?
  5. KTSmith
    KTSmith Well-Known Member
    Jul 4, 2007
    608
    Maine, New Hampshire
    Here's a case where even if the tree was 100% healthy and happy, it's too dang close to the porch by a meter or more. I realize that the tree predates the porch. Start again, preferably after you have all the house/porch/hardscaping done.
    evo likes this.
  6. JoshR
    JoshR Active Member
    Jan 17, 2015
    150
    Alabama
    Yes I understand that it is too close. I thought about transplanting it further away but, considering my experience in transplanting is limited and I knew there was a risk of it dying anyways so I just opted for trying to pull it over and if it lived maybe it could be a neat tree for the kids later on down the road.
  7. JoshR
    JoshR Active Member
    Jan 17, 2015
    150
    Alabama
    Colb, my hand saw wasn't with me when I decided to cut a few of those limbs so I used my loppers. I Haven't cleaned the knobby ones up yet? Was there anything else you noticed about my cuts?
    I don't remember for sure how deep I planted it but, I probably planted it so that the roots would have been maybe an inch or 2 underneath the surrounding ground. That's what I've done with some shrubs that I've tried to salvage.
    The bed around it is some cedar stump grindings I put around it to try to give it some organic material to absorb as it decayed.
    Last fall I did spray some roundup on the grass. I haven't watered it much anymore as well. Last summer was exceptionally dry. We actually are still considered to be in a long term drought. So maybe hat has something to do with it?
    My response may seem a little bit all over the place but thanks for your response!
  8. colb
    Jun 12, 2014
    760
    Florida
    Hi @JoshR , proper pruning cuts usually occur precisely at the outside edge of the branch collar. Try gross cutting out away from the trunk, then cutting off the remaining unweighted stub.
    Planting below the adjacent horizon is generally a long-term sentence to malaise, for a plant. Plant just above next time, accounting for settling in addition.
    Mulch should be a few inches off the trunk to promote airflow and avoid trunk rot.
    Maples where I am at are often weak in appearance and a bit of a primary successional tree, often in wetlands. Yours, planted high and dry, looks out of place, to me, but I defer to your local ecologists... Yours isn't the first maple to bite it, if it does. I respectfully disagree that it was planted too close to the structure (considering how you have trained it - good work!), but I would personally choose a bit more distance next time...
    Better get that strap out too...
    JoshR likes this.
  9. JoshR
    JoshR Active Member
    Jan 17, 2015
    150
    Alabama
    I just came across this in one of shigo's books. Anyone think this is valid?
  10. JD3000
    Aug 28, 2016
    4,045
    Columbus
    As far as it happens? Yes.
    In your case the tree was moved so infection and decay could have moved up from a severed root. Within the realm of possibilities.
  11. JoshR
    JoshR Active Member
    Jan 17, 2015
    150
    Alabama
    The tree was not moved. I considered it but opted for flexing it over. But I did sever a root when digging a post for the porch though.
    So that's what I thought when I came across that page in the book. That is, the root got some infection or something of that nature, from the open wound of the root.
    I wonder if the vessels in the portion of wood that died were directly connected to the root that was cut.
  12. JD3000
    Aug 28, 2016
    4,045
    Columbus
    Coulda sworn you said it was moved, musta had it mixed up with the post digging
  13. JoshR
    JoshR Active Member
    Jan 17, 2015
    150
    Alabama
    All good. Thanks for talking with me about it.
    JD3000 likes this.
  14. evo
    evo Well-Known Member
    Mar 26, 2009
    1,938
    My Island, WA
    Some species root y is in direct continuity with branch x. Others are more diffuse... Maple is one of the y to x trees...
    JoshR likes this.
Share This Page
